TwinTurbo.NET: Nissan 300ZX forum - Replace the oil cooler hose with OEM
Subject Replace the oil cooler hose with OEM
Posted by jdubs on April 18, 2011 at 8:40 AM
  This message has been viewed 270 times.
In Reply To Leaking oil filter bracket posted by EUGENE on April 16, 2011 at 03:23 AM
Message Mine leaked when it was cold and the OEM replacement eliminated any issue.
Oil only enters the line when prx gets too high via a check valve on the oil filter bracket. At startup or hard driving conditions it will leak and you'll see it visibly wet on the steering rack clamp. There is little oil prx in the line during normal use.
